I am unable to download the Core Catalog files for my Home Designer Suite software. How can I manually install them?
Follow the steps below to download the catalog files to your computer, then copy them to their respective locations.
It is recommended to create a folder on your computer, in an easy to access location such as your desktop, where you can save these files to, otherwise they will download to whatever default location your web browser is set to, typically your Downloads folder.
Referenced Files are compressed .zip folders and need to be copied as-is; do not open or extract the contents of these files.
Open both the folder containing the downloaded files, as well as the destination location where the catalog files will be copied to, then copy or move the files into the correct location.
%programdata%
and press OK.
/Library/Application Support
and press Go.
Home Designer Suite 2023
Download and save these Core Libraries for Home Designer Suite 2023:
Download and save these Referenced Files for Home Designer Suite 2023:
Home Designer Suite 2022
Download and save these Core Libraries for Home Designer Suite 2022:
Download and save these Referenced Files for Home Designer Suite 2022:
Home Designer Suite 2021
Download and save these Core Libraries for Home Designer Suite 2021:
Download and save these Referenced Files for Home Designer Suite 2021:
Home Designer Suite 2020
Download and save these Core Libraries for Home Designer Suite 2020:
Download and save these Referenced Files for Home Designer Suite 2020:
Home Designer Suite 2019
Download and save these Core Libraries for Home Designer Suite 2019:
Download and save these Referenced Files for Home Designer Suite 2019:
Home Designer Suite 2018
Download and save these Core Libraries for Home Designer Suite 2018:
Download and save these Referenced Files for Home Designer Suite 2018:
Home Designer Suite 2017
Download and save these Core Libraries for Home Designer Suite 2017:
Download and save these Referenced Files for Home Designer Suite 2017:
Home Designer Suite 2016
Download and save these Core Libraries for Home Designer Suite 2016:
Download and save these Referenced Files for Home Designer Suite 2016:
