Sometimes, when I select File> Send to Layout , a message says,
"No layout view or file was found. Would you like to create a new layout window and send this view to it?"
Why does this happen?
This message may appear in Chief Architect X11/Home Designer Pro 2020 and earlier versions in the following circumstances:
If you click Yes, the program will open a new layout file and automatically give this layout file the same name as the plan that you're trying to send a view to layout from.
If you have particular layout file that you want to send views to, you should instead click No. Then, select File> Open Layout from the menu and open the layout in question. When the desired layout is open, you can send views to it.
